AWULF
Jun 06, 2023Aspirant
How to exend my network over Ethernetcable (long distance 50m)
Hello, this might be a stupid question on how to, but everybody using repeaters where the wifi signal overlaps. In my case I have (an old R7000 Nighthawk). I want to buy a new one and use the R7000...
Jun 06, 2023Guru - Experienced User
Repeater mode is only connected via wireless. AP mode, for R7000 or EAX, you have to use a ethernet connection to get them connected to work properly in AP Mode.
https://kb.netgear.com/20927/How-do-I-change-my-NETGEAR-router-to-AP-mode
- microchip8Jun 06, 2023MasterIn addition, NG firmware doesn't support Repeater mode.
- AWULFJun 07, 2023AspirantSo basicly. Between ISP and R7000 I have to setup a bridged mode as a router (already in place) and I configure a cabled connection to my extra extender in AP mode.
Cabled network R800 Lan into my Wan port of the extender.- michaelkenwardJun 09, 2023Guru - Experienced User
You could investigate Powerline Ethernet
- AWULFJun 12, 2023Aspirant
The cable is there and I have Ethernet access at my end-point. So that's not the issue.
My concern is when I configure 2 identical wifi accespoints (same name and password), one on router A and one on router B, will my devices just take over the signal without interruption? Configured in Router Mode.
