AWULF
Jun 06, 2023Aspirant
How to exend my network over Ethernetcable (long distance 50m)
Hello, this might be a stupid question on how to, but everybody using repeaters where the wifi signal overlaps. In my case I have (an old R7000 Nighthawk). I want to buy a new one and use the R7000...
AWULF
Jun 07, 2023Aspirant
So basicly. Between ISP and R7000 I have to setup a bridged mode as a router (already in place) and I configure a cabled connection to my extra extender in AP mode.
Cabled network R800 Lan into my Wan port of the extender.
michaelkenward
Jun 09, 2023Guru - Experienced User
You could investigate Powerline Ethernet
- AWULFJun 12, 2023Aspirant
The cable is there and I have Ethernet access at my end-point. So that's not the issue.
My concern is when I configure 2 identical wifi accespoints (same name and password), one on router A and one on router B, will my devices just take over the signal without interruption? Configured in Router Mode.- FURRYe38Jun 12, 2023Guru - Experienced User
You'll need to configure AP mode and need to use far apart separate channels between the two systems.
- KitsapJun 12, 2023Master
AWULF wrote:The cable is there and I have Ethernet access at my end-point. So that's not the issue.
My concern is when I configure 2 identical wifi accespoints (same name and password), one on router A and one on router B, will my devices just take over the signal without interruption? Configured in Router Mode.Sounds a lot like you are talking about roaming. Where a moving device makes a seamless transition from one Wi-Fi transmission point to another. The automatic transition depends a great deal on the device itself. The router at either location provides a signal. The device makes the connection and has to take action to make the switch from one signal to another.
Have you investigated mesh systems? Just because you have set the same SSID and password from two or more transmitter points, it does not create a mesh Wi-Fi.
- AWULFJun 13, 2023Aspirant
Meanwhile I Have ordered a AX12 and an EAX80, I'll see how that goes.
Thanks all for your input.Jo
