MauriceRojas
Dec 24, 2022Aspirant
How to extend Nighthawk R6700 v3 AC1750
Hello i have searched but it seems everything tells me how to turn this router into an extender and that's not what am looking to do. if there is a discussion that already explains this please g...
michaelkenward
Dec 24, 2022Guru - Experienced User
MauriceRojas wrote:
at each room I want to also connect a switch to connect items that need Ethernet cables and also connect the access points to those switches in a couple of rooms. One in the first floor and one in the second floor and the main router (R6700) will be in the basement.
You are asking a lot of an R6700. That's a mid range and now slightly old (2018 with its origins in 2014) router.
What do you want to do on all these connections?
Kitsap
Dec 24, 2022Master
Agree with michaelkenward on his R6700 comments. Replace your R6700 and turn your R6700 into an access point.
Depending on your needs, Netgear makes a couple of plain access points. In the AC arena, look at the WAC124. In the AX arena, look at the WAX204.
- MauriceRojasDec 24, 2022AspirantOk hadn’t thought of it that way but yes am open to buying a better router and turning the R6700 into an access point if it has that capability… so new to this… WAC =WiFi 5? WAX=WiFi 6? Hard to lay out the complete needs for all the connections but most will be hard wired with Wifi needs primarily for cell phones and gets that bring iPads and some gaming consoles like Switches for the grandkids… outside of that the wifi is not the primary means of connection… all TVs and XBoxes are hard wired… with this in mind which router would be suggested that would be capable of using the R6700 as an access point?
Thanks in advance- KitsapDec 24, 2022Master
You need to do some research. This is a good place to start. https://www.duckware.com/tech/wifi-in-the-us.html Don't try to absorb it all at once. It is a great reference. Presuming you are in the US.
Many new routers on the market. Understand your needs, check the reviews, and let your pocket book be your guide.
MauriceRojas wrote:
Ok hadn’t thought of it that way but yes am open to buying a better router and turning the R6700 into an access point if it has that capability… Yes it does. Wait until after you have a replacement router bought, connected, and configured.
so new to this… WAC =WiFi 5? Yes
WAX=WiFi 6? Yes
Thanks in advance
