Kunal2325
Feb 15, 2023Follower
How to find WPS Button on Netgear Router?
I checked my Netgear router but couldn't find WPS Button on Netgear Router. I've checked many options to solve my query, but those could have been more helpful. Please guide me through step by step process will be beneficial. Thank you so much for your attention and participation.
- KitsapMaster
Kunal2325 wrote:I checked my Netgear router but couldn't find WPS Button on Netgear Router. I've checked many options to solve my query, but those could have been more helpful. Please guide me through step by step process will be beneficial. Thank you so much for your attention and participation.
Netgear makes a number of models of routers and the WPS button is located in different places on different models.
If you would look at the label on your router and specifically identify the model of router you are asking about, someone will help you promptly.
As an option, your could put forth the effort to go to the Downloads section at the top of this page, feed in your model number, and download the user's manual. I am sure there is an index to the manual and most likely WPS is listed with a page number for reference.
Depending on the model, it is usually next to the WiFi LED.
It is easy to miss because, like the WiFi LED, it is a combined LED/Switch.
It has this symbol:
WPS
Then there is the manual.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Look for the model number on the label on the device.
