AliMazloum
Apr 13, 2022Aspirant
How to force the client to roam at a specific signal
I am trying to force my phone to roam from one R9000 to another. I read about 802.11v protocol, and I understood that the AP can send the phone a signal to disconnect from it along with the list of r...
- Apr 14, 2022
IF your using the R9000s in AP mode then they are connected via ethernet. Wireless is using separate signals and channels. They do communicate wirelessly between each other.
You'll need to contact the Mfr of the phone to ask them how it handles connections, wifi signals and it's roaming features.
Apr 13, 2022Guru - Experienced User
Its up to devices to pick and choose where they connect and how they roam. Something that can't be configured on NG routers.
You can help some by lowering the transmit power on the routers from 100% to say 50% may help.
AliMazloum
Thank you for your answer. Can I use a WLC to enforce the phone to roam?
- FURRYe38Apr 14, 2022Guru - Experienced User
Something to check to see if it works for you or not. Contact the Mfr for that product and ask about it.
- AliMazloumApr 14, 2022Aspirant
I was reading through your setup, and I noticed that you are using a modem as well as a wireless backhaul. Can we replace the modem with a backhaul as the role of the backhaul is to connect with the core network?
Again, thanks for your available time replying to my questions.
What Brand and model modem do you have now?
To get backhaul support you'll need a MESH system.
