Reaper822
May 03, 2017Aspirant
How to Get a Detailed Internet Usage for Netgear Nighthawk R7000
i have been trying to get a detailed internet usage for my network so i am able to see what devices are uising the internet and how much. is this possible on the model i have. The router is using t...
- May 07, 2017
You can get per-IP traffic stats with third-party firmware, Asuswrt-Merlin. Note, you will lose hardware acceleration, so the max throughput between WAN and LAN will drop to about 450 Mbps. If you have Gigabit speed Internet, then there may be a noticeable drop in performance.
The usual caveat emptor applies for third-party firmware.
Reaper822
May 07, 2017Aspirant
Yeah I have but that only gives an overall usage. I want to know how much each device is using
TheEther
May 07, 2017Guru
