Reaper822's avatar
Reaper822
How to Get a Detailed Internet Usage for Netgear Nighthawk R7000
i have been trying to get a detailed internet usage for my network so i am able to see what devices are uising the internet and how much.  is this possible on the model i have.  The router is using t...
  • TheEther's avatar
    TheEther
    May 07, 2017
    You can get per-IP traffic stats with third-party firmware, Asuswrt-Merlin.  Note, you will lose hardware acceleration, so the max throughput between WAN and LAN will drop to about 450 Mbps.  If you have Gigabit speed Internet, then there may be a noticeable drop in performance.
    The usual caveat emptor applies for third-party firmware.
