lancewo's avatar
lancewo
Guide
Oct 04, 2023
How to get logon prompt for access point
I'm currently using an Xfinity SB-8 router/modem. I'm using my Netgear AC1900 R6900 as an Access Point in order play videos from my external drive via the Readyshare feature. I use an old laptop to c...
  • michaelkenward's avatar
    michaelkenward
    Oct 05, 2023
    lancewo wrote:
    By 'Router', are you referring to the Xfinity SB-8 router or the NetgearR6900?  and would you know how I get get its IP address?
    Yes. The Xfinity SB-8.
    In AP mode the R6900 is no longer a router. It gets its IP address from the Xfinity SB-8.
    You'll have to check the manual for the Xfinity to work out how to get the IP address of the R6900.
    Overview of Xfinity Gateways - Xfinity Support
    Routers usually have their own IP address that you can get at with a web browser and the graphical user interface (GUI). For Netgear, the usual address is 192.168.1.1. Some brands prefer 10.0.0.1.
    Feed the IP address you find into a browser and see what happens.
    Lastly, how do I 'aim the browser' at the ip?
    Same as getting in to the router. Feed the IP address you find into a browser. (Some browsers will try to block you for security reasons. This is rubbish. It is a local address.)
    Most routers should have a list of "connected devices" look for the one that could be your R6900.
