lancewo
Oct 04, 2023Guide
How to get logon prompt for access point
I'm currently using an Xfinity SB-8 router/modem. I'm using my Netgear AC1900 R6900 as an Access Point in order play videos from my external drive via the Readyshare feature. I use an old laptop to c...
- Oct 05, 2023
lancewo wrote:
By 'Router', are you referring to the Xfinity SB-8 router or the NetgearR6900? and would you know how I get get its IP address?
Yes. The Xfinity SB-8.
In AP mode the R6900 is no longer a router. It gets its IP address from the Xfinity SB-8.
You'll have to check the manual for the Xfinity to work out how to get the IP address of the R6900.
Overview of Xfinity Gateways - Xfinity Support
Routers usually have their own IP address that you can get at with a web browser and the graphical user interface (GUI). For Netgear, the usual address is 192.168.1.1. Some brands prefer 10.0.0.1.
Feed the IP address you find into a browser and see what happens.
Lastly, how do I 'aim the browser' at the ip?Same as getting in to the router. Feed the IP address you find into a browser. (Some browsers will try to block you for security reasons. This is rubbish. It is a local address.)
Most routers should have a list of "connected devices" look for the one that could be your R6900.
michaelkenward
Oct 05, 2023Guru - Experienced User
lancewo wrote:
Today I think I accidentally granted 'allow access' to this old laptop. Therefore now when I launch routerlogin.net, it actually took me to a netgear website. I no longer get the logon/password prompt like I used to.
In AP mode, the R6900 has no control over where URLs go on the network. That is down to the router.
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But let's deal with the question you asked:
"How to get logon prompt for access point"
If you find the IP address that the router has assigned to the AP, then you can aim the browser at that.
While you are in there, you could set the R6900 to a fixed IP address. Then you can always use a web browser and the graphical user interface (GUI) to get at it.
This bit is puzzling.
I would like to go back into Netgear Genie to 'disable access' to this old laptop so that I will get the logon prompt again. Could you please advise how this can be done?
Which Netgear Genie is this? (There are several.)
If you are using the desktop app for your operating system, then the network map should show you the IP address of the AP. It should even be clickable and take you into the GUI for the R6900.
lancewo
Oct 05, 2023Guide
Hi Michael,
Could you elaborate the above statement?
I'm praying that I could get the logon prompt again : -(
Thanks Michael
- michaelkenwardOct 05, 2023Guru - Experienced User
- lancewoOct 05, 2023Guide
Hi Michael,
I got it to work. I went to my Xfinity main login and tracked down the MAC and IP of the Netgear router. Then I just entered the IP on the browser and enter my login credential and I was able to launch and configure my Netgear.
Thank you so much!!
That's the way to do it. Well done. Hope you got you back to where you wanted to be.
