kn4hh
Nov 29, 2020Tutor
How to give one of my PC's on the network a static ip address so it will not change
I am using a AC-1750 R6400 router. I have several PC's connected to my home network. I need one of my PC's to have an ip address that will not change whenever the router is booted. I remotely acce...
antinode
Nov 30, 2020Guru
> Model: R6400|AC1750 Smart WiFi Router
Is that accurate? R6400[v1] or R6400v2? Look for "Model" on the
product label. Firmware version?
> will not change
Visit http://netgear.com/support , put in your (actual) model number,
and look for Documentation. Get the User Manual. Read. Look for a
topic like "Manage Reserves [sic] LAN IP Addresses". Further reading
might not hurt, either.
Terminology: A "static" address is configured on the device itself.
What you configure on a (DHCP server on a) router is a reserved dynamic
address, not a static address. Either one should fix the address of a
device, but some implications are different, so it helps to know which
you mean.
kn4hh
Nov 30, 2020Tutor
Thanks for you assistance. Problem solved.
Bob W.
