cnbeiro
May 09, 2021Aspirant
How to have the CM1100 providing network for two Wi-Fi routers?
Hi, I am trying to have two different Wi-Fi routers connected to the CM1100. My plan is to have one WRT Wi-Fi router connected to a VPN (NordVPN) and let the other (AMPLIFI HD) not connected to any...
- May 09, 2021
The CM1100 has 2x ethernet ports. the problem isn't the modem, its the ISP. Most of the major ISP's only allow 1 public ip address for consumer lines. So you can only connect 1 device.
You can pay for more IP addresses or upgrade to business class to get more with some of the ISP's. If you do that, then you could attach more than 1 device (not through a switch though).
May 09, 2021Guru - Experienced User
- cnbeiroMay 09, 2021AspirantThanks a lot for your answer!!
