Stantona
Aug 18, 2017Aspirant
How to install firmware
I did a firmware update which killed my access to the router. How do you install an older version of firmware when I cannot get to the router? Is it possible? Others say install an older version after...
- Feb 17, 2018
Stantona wrote:
I did the reset and the power light has settled down on solid white.
This is a sign that your device is working as expected. A flashing light would be a sign of broken firmware.
So you can forget about playing around with TFTP. You should be able to install new firmware without any of that hassle.
(Might not matter but the three band lights are solid white also.)
Not sure what "band lights" are, but the manual tells me that there are lights for wifi channels among other things. If they are on, that is another sign that the device is not bust. You can read about what the lights mean in the manual somewhere at the end of this link:
>>> R8500 | Product | Support | NETGEAR <<<
see page 174.
The important one is the Intern the light. What does that look like?
Your main issue seems to be that you cannot access the router's control interface. There can be various reasons for this. One is that your playing around has confused the equipment on your network and it does not know what addresses to use. You can start from scratch and see if that restores sanity.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
Stantona
Feb 17, 2018Aspirant
This is what I did.
I disconnected the modem/router combination I was using and connected the CM600 modem, called COX and changed service to the CM600. Next to make sure I had a good signal from COX, I ran a cable from the CM600 to the computer. Worked great.
Next I connected the R8500 and just this computer and followed your instructions verbatum.
I could not believe it! This is as far as I have gotten but I am on line now with this one computer. Next I will connect the other computers, cameras, and Cox Homelife. They should work.
Some extra notes. The first thing that happened when I opened my browser was that it downloaded a Netgear Genie which asked me if I wanted to upgrade my firmware. I was reluctant but I said yes. It then upgraded my firmware to the latest and booted my router back up again and it worked. I might have left out something, but you can see that so far I am a happy camper. You have no idea how much I appreciate your help. Thank you so much.
I am now going to connect everything else and see how that goes. I see no reason it shouldn't all work now. But I will come back and let you know.
michaelkenward
Feb 17, 2018Guru - Experienced User
Excellent news.
No need for tftp or other witchcraft.
- antinodeFeb 17, 2018Guru
https://en.wikipedia.org/wiki/Clarke%27s_three_laws
"Any sufficiently advanced technology is
indistinguishable from magic."
Of course, "advanced" is relative. - StantonaFeb 17, 2018Aspirant
I said I'd get back. Everything is up and running and all devices connected.
Thanks again for your help and others who contributed.
