SophieP
Mar 21, 2023Follower
How to install NETGEAR on PC when sharing mobiles internet connection to PC
I am using my mobile´s internet connection to get wifi on my PC (sharing hotspot from mobile to PC) but I can´t seem to get NETGEAR to work. I have followed all instructions and even tried manually i...
Mar 21, 2023Guru - Experienced User
What NETGEAR wifi router model do you have? R or RAX something?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Be sure to review the installation guide and user manuals found here for your model router to set it up and get it working:
