Pls_help
Feb 07, 2021Aspirant
How to make an extender
I'd like to make my Netgear router into an extender of my ISP's required wifi router. My Netgear router is the Nighthawk X4S AC2600 R7800 I've pressed every button in the app and didn't see anythi...
- Feb 08, 2021
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Depending on how you want to connect your router to the network, wired or wireless, look in the manual for something like Use the Router as a WiFi Access Point or Use the Router in Bridge Mode
michaelkenward
Feb 08, 2021Guru - Experienced User
Support | NETGEAR
