PhamHuyBao
Mar 06, 2017Aspirant
How to optimize the file transfer speed between USB external hard drive and wired-LAN PC on R7000.
Hi everyone, Here is my configuration: I have R7000, updated to latest firmware. I connect my PC to router using Cat5e cable. I connect my USB 3.0 External Hard Drive (Western Digital 6TB) to...
- Mar 06, 2017
PhamHuyBao wrote:
I think that I will leave everything as it is and accept that the transfer speed of 30-33 MB/s is the best that I can get with R7000.
TrustedReview measured the R7000's USB speed at 28-29 MB/sec, which is approximately what you are getting. http://www.trustedreviews.com/netgear-nighthawk-ac1900-802-11ac-router-review-setup-performance-page-2
The R9000 has 100 MB/s read speed and about 55 MB/sec write speed. https://www.smallnetbuilder.com/wireless/wireless-reviews/33046-netgear-r9000-nighthawk-x10-smart-wifi-router-reviewed?showall=&start=2
PhamHuyBao
So you mean I don't need to do anything here. 30 - 33 MB/s is the best that I can get with R7000 already?
Changing cable from Cat5e to Cat6 and/or switch to use Killer NIC instead of normal Gigabit NIC won't make any difference?
schumaku
Mar 06, 2017Guru - Experienced User
Killer NIC is essentially a 1 GbE interface, tuned for lower latency when I remember my friend (a Dell sales manager) information correctly. No rocket science effects on the throughput.
Reasonable CAT5e cabling works even with 10 GbE - on a shorter reach. Unless the CAT5e cables are bad, there should not be a performance difference at all on Gigabit Ethernet when updating to CAT6 (or CAT7).
- PhamHuyBaoMar 06, 2017Aspirant
If so,
Anyone has any different opinion than schumaku?
- StephenBMar 06, 2017Guru - Experienced User
- aalexandrebetaMar 06, 2017Master
The R7000 is middle range router and the R9000 is the most extrme one so the R7000 is doing things slower than the beast!
If you do want perfs purchase a NAS it will be steady and better.
As my grand-ma said you pay for what you get!
