Syad
Aug 13, 2021Follower
How to pair MS 60 and configure satellite settings other than the preset wifi network
Hi, i have a MS60 which is pre set connected to NETGEAR09 - this was given to me by my brother who no longer needs it. So i am trying to pair this to my mesh wifi network, NETGEAR83, (currently with 1 MR60 & 2 MS60). Problem here is the 3rd MS60 is not syncing with my network as it was preset to connect to NETGEAR09. I am trying to find a way to sync and pair it into my network. Is there any way i can access to the setting of the MS60? Or is there a way i can make the 3rd MS60 into my network?
1 Reply
Syad wrote:
So i am trying to pair this to my mesh wifi network, NETGEAR83, (currently with 1 MR60 & 2 MS60).Reset the new MS60 and set it up to work with your existing MR60.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Begin with the Quick Start/Installation Guide.You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Mesh System - NETGEAR Communities
