Alierace
Oct 24, 2020Aspirant
How to permanently remove "Circle" pop-up
FW V1.0.11.100_10.2.100 has "Circle" pop-up that has no option to hide it. Every time you login into router, it pops up. Is there a way to disable it permanently?
- Oct 24, 2020
I was a browser cookie issue. Can MOD delete my post as i cannot find a way to do it myslef.
Alierace
jlwilkinson
Nov 18, 2020Aspirant
If it was a "browser cookie issue" please define HOW you resolved it. I get this on different browsers on different machines.
- AlieraceNov 18, 2020Aspirant
jlwilkinson wrote:If it was a "browser cookie issue" please define HOW you resolved it. I get this on different browsers on different machines.
I cleared browsing history "all time" not just session and after login to router, closed the pop-up. logout without closing, login back and repeat couple times till no more popups. After that it somehow remembered and stayed put :), maybe it has an internal pop-up count.. idk.
- jlwilkinsonNov 18, 2020Aspirant
Thanks for the much clearer explanation. I'll try that.
- NeonsparkNov 26, 2020Aspirant
If you have an ad-blocker addon (I use uBlock) you can add this to your filters to remove it :
##.circle-modal
That worked for me.
(Which is stupid, shouldn't have to do that there should be a DONT SHOW AGAIN checkmark.)
