jgwdoc
Jul 03, 2023Guide
How to reboot Nighthawk R7000P remotely
I have a Nighthawk R7000P router hooked to a cable modem which routinely crashes (about once a month), and my security cameras are dependent on the router . Re-setting it when I'm home just requires ...
- Nov 14, 2023The Keep Connect smart plug completely solved the issue. It senses any interruption and reboots until the connection is reestablished. You can also monitor the status of the KC plug via internet and use multiple KC plugs for a more complex network.
SantaFeEngraver
Nov 14, 2023Aspirant
Hello! Curious to know if you ever solved your issue. Mine is very similar on a number of fronts. I too am reliant on my system for WiFi security cameras for an 2nd home where we live 50% of the time and if there is a brief power outage, and sometimes even if not — the modem goes offline. I have XFINITY service, that confirms no WiFi outage. I have neighbors that confirm power is on. I have to have a friend go into the house, unplug the Netgear Nighthawk Cable Modem for 30 seconds, plug it back in — and then my Orbi routers immediately go right back online.
Not familiar with that smart plug — will be researching that.
jgwdoc
Nov 14, 2023Guide
- SantaFeEngraverNov 18, 2023AspirantThanks. I think I’m going to give the KC a shot. Maybe one for router and one for modem. Seems highly likely to solve my issue — and if so, at a relatively low cost.
- michaelkenwardNov 18, 2023Guru - Experienced User
SantaFeEngraver wrote:
Thanks. I think I’m going to give the KC a shot. Maybe one for router and one for modem. Seems highly likely to solve my issue — and if so, at a relatively low cost.Could be a good idea.
In the past I have found that modem and router can get out of synch.
What happens is that the modem takes so long to reboot that the router has already thrown in the towel and timed out before the modem has a connection. This then ends up with a dead network even though the modem has an internet connection.
