McSteve
Aug 09, 2022Aspirant
How to remove antennas from R7000?
I have an existing Mesh network (not Netgear devices) and I am replacing a dead Router with a new R7000. I use ExpressVPN, thus the R7000 has ExpressVPN's firmware in it. Accordingly, I do not use or...
Aug 09, 2022Guru - Experienced User
You can't remove those. They are permanently attached. I would recommend just leaving them. Turn then down so they are not in the up position.
