McSteve
Aug 09, 2022Aspirant
How to remove antennas from R7000?
I have an existing Mesh network (not Netgear devices) and I am replacing a dead Router with a new R7000. I use ExpressVPN, thus the R7000 has ExpressVPN's firmware in it. Accordingly, I do not use or...
ladyintown
I don't think it you can remove the anteena. However, if there is any must share it with me
- FURRYe38Aug 09, 2022Guru - Experienced User
Those type of antenna connectors are not removable. They are permanent. I guess NG came out with two versions of the R7000 as my R7000 I have has the removable un-screwable antennas. I guess later versions of the R7000 were made not removeable.
