siamak
May 03, 2023Aspirant
How to reset e-mail and password
I just bought the subject product from a friend. He does not remember the e-mail address and the password on the router. How do I reset these? When I connect to the router, it does not allow me to se...
- May 03, 2023
Not much to go on.
What NG product model are you referring too?Has a factory reset and setup from scratch been performed? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-routerRecommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
May 03, 2023Guru - Experienced User
Not much to go on.
