loren339alpha
Jul 12, 2022Follower
How to reset R8000 according to the default settings
I have messed with the nighthawk settings by mistake and now I am unable to surf the internet. Can you help me to reset the nighthawk to the factory settings.
Jul 12, 2022Guru - Experienced User
Press the reset button in back for 10 seconds then set up from scratch using a wired PC and web browser.
