Crazyhuntaholic
Jul 30, 2022Aspirant
how to return a router to get repaired
I refuse to buy a new router. I have a R7000P. Too expensive for it to come out the box broken. how much and how do I get this thing sent it to get it fixed. And no before you start asking whats wron...
Aug 01, 2022Guru - Experienced User
If you just bought it, return it from where you got it. That's going to be the fastest process.
michaelkenward
That's what I thought but Crazyhuntaholic has been drip feeding details into several conversations here and this seems to be an "old" router they never worked out how to use. Too old for an RMA.
Has anyone figured out how to fix a bricked router... - NETGEAR Communities
- wcalifasAug 05, 2022Prodigy
did you try the tftp method to unbrick it?
