Nicolus008
Dec 23, 2021Aspirant
How to separate RBR40 2.4GHz and 5GHz
I cannot to install Alro pro 4 cam, because it is use the 2.4 GHz. I have two question. How To disable the 5GHz, because there do not have the checkbox to click the disable the 5GHz. How to cra...
Dec 23, 2021Guru - Experienced User
You shouldn't need to disable the 5ghz or seperate them out.
Did you contact Arlo for support with connecting their camera?
- Nicolus008Dec 23, 2021Aspirant
Hi Plemans,
Thank you for your replied, I sent the message to arlo for setting isses.
But RBR40 can separte and I can choice use 2.4GHz or 5GHz?
I know other brand router can setting it.
- plemansDec 24, 2021Guru - Experienced User
No. the orbi series you can't seperate the bands.
- Nicolus008Dec 24, 2021Aspirant
So I need to buy other brand router, right?
