Nicolus008
Dec 23, 2021Aspirant
How to separate RBR40 2.4GHz and 5GHz
I cannot to install Alro pro 4 cam, because it is use the 2.4 GHz. I have two question. How To disable the 5GHz, because there do not have the checkbox to click the disable the 5GHz. How to cra...
