schoolbus
Nov 14, 2017Aspirant
How to set NighthawkR7000 to repeater mode
Hello, I just bought a netgear Nighthawk R7000 (AC1900 Smart Wifi) and am trying to figure out how to set it to REPEATER Mode. I follow the instructions to get up to Step 5 on this webpage: ht...
- Nov 15, 2017
Hi schoolbus,
Check this KB article below.
https://kb.netgear.com/24108/How-do-I-configure-my-Nighthawk-router-as-a-wireless-repeater
antinode
Nov 14, 2017Guru
> I am using GENIE.
Which "GENIE"? Ever helpful, Netgear uses the name "Genie" for more
than one thing. Netgear routers have a web-browser interface called
"Genie", and Netgear offers application programs for various
computers/pads/phones, which are also called "Genie".
> https://kb.netgear.com/24108/[...]
Use a wired Ethernet connection to set up the repeater unit to
avoid conflicts with the wireless connection.
In other words, use the web-interface "Genie", not a "Genie" app.
- schoolbusNov 14, 2017Aspirant
I appreciate the reply, but this advice doesnt answer my question.....
The Genie I am referring too is the App that helps you to configure the router etc.
Can someone tell me what the webpage (see link in my post above) is referring too in its instructions for the Step # that I am stuck at? I see NO advanced tab or button or link.
Also, I cannot hardwire it otherwise I would. WIFI signal interference is not an issue.
Configuring the Netgear Router to be a repeater is the issue I am asking about.
Sincerely,
Schoolbus
To clarify, Genie is a webbrowser interface for configuring the router.
I hope my terminology is correct.
Schoolbus
- antinodeNov 15, 2017Guru
> router etc.
> router.
Clear as mud. Are you running some Genie app on some device, or are
you running a web browser, and pointing it at the router?
The web-browser interface on these devices has a main page which says
"NETGEAR genie", and has "BASIC" and "ADVANCED" tabs. I don't know what
you are looking at.
> asking about.
And just as soon as you find the web interface, we can worry about
what you want to do with it.
