corvairbob's avatar
Jan 29, 2020
how to set this box? in the advance - setup -
i have researched thisDisable Port Scan and DoS Protection  and i just do not see a real answer. i see both answers. some say check that box and some say leave it alone.  i had to do a factory reset ...
  • corvairbob's avatar
    corvairbob
    Jan 30, 2020
    and to this one  michealkenward   i did got to that page and in the usb page i was asking if anone had a answer for what usb devices work with the c7000 modem router.
    with the old modem i had i fo to that page and it would give me 3 usb devices that it liked and then a box that said try anu usb device and see if it may work.
    on the c7000 modem that option is not anywhere in the 3 choices. and in advance i see it has some items checked for enable and then some for  needing to input a admin type password. so that is about as clear as mud. so because it is hard to get that one answered i will just forget about evenusing that port onthe back the device. but thanks for trying  jsut mark it solved. or the next reply i get i will just accept it and move one. thanks
