126mon's avatar
126mon
How to setup an QoS rule on a R7500?
I'm looking to setup an QoS rule to limit some the speed of some devices connected to my router. But I can't seem to find where to set it up at. The only thing I can find is the Dynamic QoS.
  • Look under connected devices. Select one of these devices and it may open up a new window with Priority listings. You might be able to select High, Medium or Low. Do this for each device you want to have a priority for.
  • FURRYe38's avatar
    • 126mon's avatar
      126mon
      Thank you, will this have to be set daily? Or will it stay in effect after it's placed?
      • FURRYe38's avatar
        It should be persistent for each device.
