mtp1032
Dec 01, 2020Tutor
How To Setup Two separate Wireless Networks?
My home network uses the Pakedge RE-2 muiltizone mesh network. I need to establish a second independent WiFi because the weather monitor system I've just aquired cannot be installed using a mesh netw...
Dec 01, 2020Guru - Experienced User
I haven't found a IoT/smart device that can't be connected to a mesh system.
What I have found is lazy coders who force your phone/setup device to be on the same 2.4ghz band the smart device uses for setup.
If you're netgear router is using bandsteering, it might have your phone on the 5ghz and the weather station not be able to connect to it for setup. Same with your pakedge system.
make sure your phone/tablet/setup device is on the 2.4ghz during setup. You could do this with the netgear or you might even be able to get the pakedge system working without needing the other router.
If you want to get the netgear working, disable bandsteering (also called smart connect) and give the 2.4ghz a different name from the 5ghz. That way you can ensure you connect to the 2.4ghz. If you leave the 2.4ghz with the name you'll have once its setup, when you re-enable bandsteering, the smart device should auto-connect to the smart device.
- mtp1032Dec 01, 2020Tutor
I'm a former software engineer (o/s and drivers, not networks) and I couldn't agree more with your comment about lazy coders. I'll give your suggestion a whirl. Thanks
- plemansDec 01, 2020Guru - Experienced User
good luck!
Like I said, I haven't found one I couldn't get connected with a little work.
Not trying to push you away from netgear but if you're already got a solid mesh system, another router only adds potential interference
Replied on this post instead of the other one. :)
I was looking at the manual for pakedge. Seems they have a dhcp leases section and other connected devices section. Might be worth looking under that section for the netgears IP address. I attached a screen snip of it
