mtp1032
Dec 01, 2020Tutor
How To Setup Two separate Wireless Networks?
My home network uses the Pakedge RE-2 muiltizone mesh network. I need to establish a second independent WiFi because the weather monitor system I've just aquired cannot be installed using a mesh netw...
mtp1032
Dec 01, 2020Tutor
I'm a former software engineer (o/s and drivers, not networks) and I couldn't agree more with your comment about lazy coders. I'll give your suggestion a whirl. Thanks
Dec 01, 2020Guru - Experienced User
good luck!
Like I said, I haven't found one I couldn't get connected with a little work.
Not trying to push you away from netgear but if you're already got a solid mesh system, another router only adds potential interference
- plemansDec 01, 2020Guru - Experienced User
Replied on this post instead of the other one. :)
I was looking at the manual for pakedge. Seems they have a dhcp leases section and other connected devices section. Might be worth looking under that section for the netgears IP address. I attached a screen snip of it
