charleyrich
Dec 19, 2020Aspirant
How to turn off WPS on C7800?
How can I trun off WPS on a C7800? I went through all the options in basic and advanced and don't see an option to disable WPS. The WPS Wizard is where it seems this is configured doesn't offer an ...
- Dec 20, 2020
> [...] my screen for wireless, advanced doesn't look like what the
> manual shows for tht screen. [...]_Which_ "wireless, advanced"? Netgear's management interface
structure has some potentially confusing quirks. Compare, for example:ADVANCED > Setup > Wireless Setup
and
ADVANCED > Advanced Setup > Wireless Settings
Dec 19, 2020Guru - Experienced User
there isn't an option to fully disable wps. You can disable the pin based method.
- charleyrichDec 19, 2020Aspirant
Thanks, but unfortunately that procedure doesn't apply to the C7800. IT doesn't seem to offer a way to ""Disable Router's PIN" option, or uncheck the "Enable Router’s PIN"
Any other suggestions?
plemans wrote:there isn't an option to fully disable wps. You can disable the pin based method.
- plemansDec 19, 2020Guru - Experienced User
the manual shows it as being an option under: ADVANCED > Advanced Setup > Wireless Settings.
Page 74 of the manual
https://www.downloads.netgear.com/files/GDC/C7800/C7800_UM_EN.pdf
- charleyrichDec 20, 2020Aspirant
plemans wrote:the manual shows it as being an option under: ADVANCED > Advanced Setup > Wireless Settings.
Thanks for the help. Unfortunately, my screen for wireless, advanced doesn't look like what the manual shows for tht screen. I wonder if the version of firmware I have has altered the menu v3.01.43.
