charleyrich
Dec 19, 2020Aspirant
How to turn off WPS on C7800?
How can I trun off WPS on a C7800? I went through all the options in basic and advanced and don't see an option to disable WPS. The WPS Wizard is where it seems this is configured doesn't offer an ...
- Dec 20, 2020
> [...] my screen for wireless, advanced doesn't look like what the
> manual shows for tht screen. [...]_Which_ "wireless, advanced"? Netgear's management interface
structure has some potentially confusing quirks. Compare, for example:ADVANCED > Setup > Wireless Setup
and
ADVANCED > Advanced Setup > Wireless Settings
charleyrich
Thanks, but unfortunately that procedure doesn't apply to the C7800. IT doesn't seem to offer a way to ""Disable Router's PIN" option, or uncheck the "Enable Router’s PIN"
Any other suggestions?
plemans wrote:there isn't an option to fully disable wps. You can disable the pin based method.
Dec 19, 2020Guru - Experienced User
the manual shows it as being an option under: ADVANCED > Advanced Setup > Wireless Settings.
Page 74 of the manual
https://www.downloads.netgear.com/files/GDC/C7800/C7800_UM_EN.pdf
- charleyrichDec 20, 2020Aspirant
plemans wrote:the manual shows it as being an option under: ADVANCED > Advanced Setup > Wireless Settings.
Thanks for the help. Unfortunately, my screen for wireless, advanced doesn't look like what the manual shows for tht screen. I wonder if the version of firmware I have has altered the menu v3.01.43.
- antinodeDec 20, 2020Guru
and
ADVANCED > Advanced Setup > Wireless Settings- charleyrichDec 20, 2020Aspirant
antinode wrote:> [...] my screen for wireless, advanced doesn't look like what the
and
ADVANCED > Advanced Setup > Wireless SettingsThanks!
The 2nd path "ADVANCED > Advanced Setup > Wireless Settings" - had the setting. Weird that they have two ways to get to this, both catagorized as "advanced" with different options. Someone needs to go back to UI Design school...
I made the change, the gateway did its reset, but I noticed the WPS light is still on the gateway! Is it really off?? If I click the WPS button it does its blinking thing. I unchecked "Enable Gateway's pin" But, I suspect WPS is still enabled. There are 2 other buttons net to pin entitled keep wireless settings (2.4 and 5). Disabling them does not seem to make a difference. In fact after applying this change they turn themselves back on... fun...
