charleyrich's avatar
charleyrich
How to turn off WPS on C7800?
How can I trun off WPS on a C7800?  I went through all the options in basic and advanced and don't see an option to disable WPS.  The WPS Wizard is where it seems this is configured doesn't offer an ...
  • antinode's avatar
    antinode
    Dec 20, 2020
    > [...] my screen for wireless, advanced doesn't look like what the
    > manual shows for tht screen. [...]
       _Which_ "wireless, advanced"?  Netgear's management interface
    structure has some potentially confusing quirks. Compare, for example:
          ADVANCED > Setup > Wireless Setup
    and
          ADVANCED > Advanced Setup > Wireless Settings
