Arthur19
Nov 27, 2020Follower
How to update C6300
Nov 27, 2020Guru - Experienced User
microchip8 is correct. The C6300 gets its updates directly from the isp. The end user can't update it.
you can check if you're on the version your isp supports.
- michaelkenwardNov 28, 2020Guru - Experienced User
In addition to the other comments – they are correct – you could check other messages about your hardware.
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Cable Modems & Routers
