aragonl
Oct 09, 2021Follower
How to update firmware in R8000P bridged (not primary router) router?
My current configuration is: Modem to Model RAX45 (AX4300), then using bridge function to Model R8000P (AC4000).
Is there a method to update the AC4000 firmware while in the above configuration? I can't add the AC4000 to the app without removing the AX4300.
Thanks!
1 Reply
- KitsapMaster
Strongly recommend you DO NOT update the firmware of anything via an app. Way too many problems arise as a result. Specifically corrupt firmware.
If you feel you need to update the firmware, I strongly recommend you do so manually via an ethernet connection cable to the device and using a web browser on a computer. If that is not convienent from a location standpoint, disconnect the device, move it to perform the update and then move it back.
