whitedp
Oct 11, 2022Tutor
How to Update R7000 from 1.0.3.68?
Hello. A friend has an R7000 router currently still using firmware 1.0.3.68_1.1.31 and I tried to update it via the control panel's Check for new firmware mechanism. All it ever did was say "trying t...
Oct 11, 2022Guru - Experienced User
Download the FW file needed and manually install it using a wired PC and web browser using the manual tab:
https://kb.netgear.com/23960/How-do-I-manually-update-the-firmware-on-my-NETGEAR-router
whitedp
Oct 11, 2022Tutor
Thanks. So there is no problem in trying to make the jump from 1.0.3.68 all the way to 1.0.11.136 in a single bound? Again, I am very concerned about possibly bricking or otherwise messing up the router since I am doing it remotely for a very non-technical friend. Thanks
- FURRYe38Oct 11, 2022Guru - Experienced User
Should not be any problems if they follow the instructions.
Again use a wired PC and web browser. MS Edge in Windows or Safari for Apple.
