Hankl78's avatar
Hankl78
HP 6830 Red Port light and offline
My printer is connected to the R7800 via ethernet cable and the port(3) light is Red. I've tried changing cables and ports with the same result. When accessing the port 192.168.1.14 thru the HP Statu...
  • ElaineM's avatar
    ElaineM
    Mar 23, 2017
    Just a quick note, if it's amber it means that the device plugged in is not maximizing the speed that the router can offer which is up to 1Gbps.
    Perhaps, the printer is only capable of up to 100Mbps. You may check this from the LAN specification of the printer.
