Hankl78
Mar 22, 2017Aspirant
HP 6830 Red Port light and offline
My printer is connected to the R7800 via ethernet cable and the port(3) light is Red. I've tried changing cables and ports with the same result. When accessing the port 192.168.1.14 thru the HP Statu...
- Mar 23, 2017
Just a quick note, if it's amber it means that the device plugged in is not maximizing the speed that the router can offer which is up to 1Gbps.
Perhaps, the printer is only capable of up to 100Mbps. You may check this from the LAN specification of the printer.
ElaineM
Mar 23, 2017NETGEAR Employee Retired
