Bagchip
Nov 02, 2021Aspirant
HP MFC M29 WiFi keeps blinking
Hi -I just installed Nighthawk. While it connected without problem to my computers and phones, but it CANNOT DO SO WITH HP MFC M29w printer. Any suggestions? Thanks
- Nov 03, 2021I was able to get it work with hp help. Thanks
Nov 03, 2021Guru - Experienced User
What model router did you install?
Contact HP support for help and information regarding there printer as well.
Bagchip
Nov 03, 2021Aspirant
AX5200 model
- FURRYe38Nov 03, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6Might disable AX mode on 2.4Ghz to see if this helps any.
Thank you.
