srp's avatar
srp
Hp Web Services
I've had a couple of weeks of technical breakdowns.  First my router which I replaced with this Netgear Nighthawk and then my printer which I replaced with a HP8715.  It's the combination of router a...
  • srp's avatar
    srp
    Mar 27, 2017
    Everything connected to the router fine and the printer connects wirelessly and works fine it just couldn't connect to the HP Web Services which it does perfectly well with an old router
    The only advice from HP was to give it a static IP address and change the DNS :-(
    Anyhow, for the benefit of other forum users, after another fumble around yesterday I have managed to resolve the issue.  I reset the router and the printer to factory settings and brought them both back up - voila it works!
    All a bit annoying really given the amount of hours wasted and the frustration, but pleasing nevertheless
