Thunder99
Apr 09, 2022Aspirant
HTTP 401
error HTTP 401, how to fix this ?
- Apr 09, 2022
error happened after trying to reset password here (hitting CANCEL for the password to reset it) :
www.routerlogin.net
But not an issue anymore; because I have figured out the old password.
Thanks Anyway.
Apr 09, 2022Guru - Experienced User
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.For what?
You gave us nothing other than an error.
Not the equipment you're using, what you were doing to cause, or whats you're actually trying to do.
- Thunder99Apr 09, 2022Aspirant
Thanks
