philostow
Dec 12, 2021Guide
http://192.168.1.1/USB_Folder_edit.htm?editFolderID=0
I recently has to reset my router. Everything is back in working ordeer except that I cannot configure my USB drives. When I clieck edit or create network folder I get a popup with no content! See...
philostow
Dec 12, 2021Guide
I have also tried using edge. I've done this successfully with Chrome in the past. Thanks
Dec 12, 2021Guru - Experienced User
Be sure you don't have any ad blocking or popup window blocking add-ons in the browsers.
Be sure to clear out ALL browser caches prior to entering in the routers web page.
- philostowDec 12, 2021GuideTried all that. Thanks
- philostowDec 13, 2021Guide
Sometimes when I click on the Readyshare advanced tab the screen shows up blanks! I've tried using Google, Edge, and Firefox. This all was working last week! This is very frustrating. I've even tried using different USB flash drives (sizes and brands).
- FURRYe38Dec 13, 2021Guru - Experienced User
Sounds like something in FW is broke.
You might downgrade back to what worked.
You also should try Voxels 3rd party FW for the R9000 he develops for.
