philostow
Dec 12, 2021Guide
http://192.168.1.1/USB_Folder_edit.htm?editFolderID=0
I recently has to reset my router. Everything is back in working ordeer except that I cannot configure my USB drives. When I clieck edit or create network folder I get a popup with no content! See...
philostow
Dec 14, 2021Guide
Good idea, downgrading the firmware. I just tried that but no joy. Returned to latest FW and kept trying. Evenetually if I let the empty popup "stew" for awhile, I noticed that the shares worked. Bizarre. Maybe after doing some research I'll look into the 3rd party sw you recommended. I used to run ddwrt fw on my old netgrear 54G router! Thanks.
Dec 14, 2021Guru - Experienced User
Wondering if there is some USB enumeration hang time happening. Is there any drive LED activity when this popup window appears?
Glad it started working.
- philostowDec 14, 2021Guide
Thanks. Don't recall.
- FURRYe38Dec 14, 2021Guru - Experienced User
Enjoy. 📡
