sgardner
May 09, 2024Aspirant
Hulu stopped working - VPN connection? Nighthawk R7000P
All of a sudden Hulu stop working on App and TV while connected to Wifi. If not connected to WIFI the app works on my phone. While the TV and Apps are connected to WIFI I get the error of "Hulu is no...
May 09, 2024Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Check if your using VPN.
Try with out VPN?
sgardner
Thank you for your answer. This did not work and still experiencing same issue. I do not know how to check if I am using a VPN - nothing points to me using a VPN. All other Apps work and nothing has changed for me.
Do you have any other suggestions?
Thanks!
- FURRYe38May 09, 2024Guru - Experienced User
What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?Contact the VPN provider?
Can try a factory reset and setup from scratch on the router at some point.
- michaelkenwardMay 09, 2024Guru - Experienced User
If you haven't installed a VPN, it isn't likely that you are using one. They don't arrive by magic.
Do you have any security software installed that might be getting in the way?
Google has rather a lot of hits on "Hulu stop working - Google Search.
Hard to see how a router could suddenly intervene.
