sgardner
May 09, 2024Aspirant
Hulu stopped working - VPN connection? Nighthawk R7000P
All of a sudden Hulu stop working on App and TV while connected to Wifi. If not connected to WIFI the app works on my phone. While the TV and Apps are connected to WIFI I get the error of "Hulu is no...
sgardner
Thank you for your answer. This did not work and still experiencing same issue. I do not know how to check if I am using a VPN - nothing points to me using a VPN. All other Apps work and nothing has changed for me.
Do you have any other suggestions?
Thanks!
May 09, 2024Guru - Experienced User
Contact the VPN provider?
Can try a factory reset and setup from scratch on the router at some point.
