woole
Jun 02, 2024Follower
I am not seeing advertised WiFi speed
I have Netgear 7000 and WiFi advertised speed of 1.9 Gbps (using DD-WRT). I ran some test and I am seeing 230 mbps max under AC only configuration on 5 GHz -- it's right next to me -- no interference...
Jun 02, 2024Guru - Experienced User
Something to post over on the DD-WRT forums if you have there FW loaded. This forum is for stock FW.
FYI:
https://www.increasebroadbandspeed.co.uk/realistic-speeds-wi-fi-5-and-wi-fi-6
https://www.wiisfi.com
https://support.google.com/fiber/answer/6250056#zippy=%2Cmobile-devices-wi-fi
Good Luck
