JimP1984's avatar
JimP1984
I AM ONLY SEEING HALF MY BANDWIDTH SPEEDS FROM MY ISP ON MY ROUTER R6700V3
Not doing anything fancy here.  I have confirmed that my WAN and LAN1 Connections are capable and connected at 1GB.  My router is Nighthawk R6700V3.  The router has the latest firmware version V1.0.4...
  • JimP1984's avatar
    JimP1984
    Mar 06, 2023
    So, Got the problem resolved with a factory reset that was applied after the most recent firmware version was reinstalled. Systematic reboots never resolved the bandwidth issue. A factory reset had to be done. Thanks for your reply and information!
