JimP1984
Mar 04, 2023Aspirant
I AM ONLY SEEING HALF MY BANDWIDTH SPEEDS FROM MY ISP ON MY ROUTER R6700V3
Not doing anything fancy here. I have confirmed that my WAN and LAN1 Connections are capable and connected at 1GB. My router is Nighthawk R6700V3. The router has the latest firmware version V1.0.4...
- Mar 06, 2023So, Got the problem resolved with a factory reset that was applied after the most recent firmware version was reinstalled. Systematic reboots never resolved the bandwidth issue. A factory reset had to be done. Thanks for your reply and information!
Mar 04, 2023Guru - Experienced User
What speeds are you seeing?
Speed testing with a wired PC?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
JimP1984
Mar 06, 2023Aspirant
- FURRYe38Mar 07, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
