JimP1984
Mar 04, 2023Aspirant
I AM ONLY SEEING HALF MY BANDWIDTH SPEEDS FROM MY ISP ON MY ROUTER R6700V3
Not doing anything fancy here. I have confirmed that my WAN and LAN1 Connections are capable and connected at 1GB. My router is Nighthawk R6700V3. The router has the latest firmware version V1.0.4...
- Mar 06, 2023So, Got the problem resolved with a factory reset that was applied after the most recent firmware version was reinstalled. Systematic reboots never resolved the bandwidth issue. A factory reset had to be done. Thanks for your reply and information!
JimP1984
Mar 06, 2023Aspirant
Mar 07, 2023Guru - Experienced User
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
