mypotato
Apr 02, 2016Aspirant
I am unable to download the larger files using ReadyCloud. Please Help Me!
I have a Nighhawk R7000 router. After I first set up my ReadyCloud I was able to download some of the larger files stored on it. Recently I found out it is limiting them to a very small size. I wo...
- Apr 17, 2016
Hi mypotato,
Please provide an update or any feedback when using the beta firmware. Your information will be helpful to us.
mypotato
Apr 04, 2016Aspirant
It is firmware version V1.0.6.28_1.1.83.
JamesGL
Apr 05, 2016NETGEAR Employee Retired
Hi mypotato,
This firmware has been pulled out from support site. I would suggest you revert back to v1.0.4.30 or use the beta firmware v1.0.6.40(here). Reset the manually reconfigure after changing the firmware.
- mypotatoApr 09, 2016Aspirant
I have changed the firmware back to V1.0.4.30_1.1.67. Unfortunately this has still not corrected my issue. I am able to download smaller files through ReadyCloud, but still unable to download larger files. I have tried this on multiple computers off of my home network and they all seem to limit out the same. Please Help!
- JamesGLApr 11, 2016NETGEAR Employee Retired
Hi mypotato,
Try this beta firmware and provide an update.
https://community.netgear.com/t5/Nighthawk-WiFi-Routers/R7000-Beta-FW-1-0-5-60/m-p/1070857#M30302
- JamesGLApr 17, 2016NETGEAR Employee Retired
Hi mypotato,
- mypotatoApr 17, 2016Aspirant
This seems to have fixed my problem. Thanks so much for your help!!!
